change mtu on wan interface
Aondio_Carlo
Hi, i have a problem with a new fiber connection that use a mtu lower.
For not change all the mtu size on the client it's possible change the size on tha wan on lan interface of mx80?
Thank
Best regards
MilesMeraki
Hello @Aondio_Carlo, Yes the MTU Size can be changed on the WAN interfaces. You'll have to open a support case with Meraki support (help>get help ). Tell Meraki support the desired MTU size and they can set it on your MX for you.
8 Replies 8
MilesMeraki
Aondio_Carlo
Hi, thank for answer. I have open a support cases and i wait the answer from them.
Thank
AndreasE
Hi all,
if an MX device needs to be replaced (RMA case), would the replacement device get the same MTU size setting that the broken one had configured (by Meraki Support)?
Or do we have to open a new case right after the device has actually been replaced?
Rgds, Andreas
joopv
I'm also interested in an answer to this question.
joopv
Can this also be done on a template ?
AndreasE
Ha, I would be so glad if I could configure it manually at all -- not to dream of a template...
SPG-Bill
I just have to say, 7 years later and we still cannot see or change the MTU in the Dashboard.  This complicates troubleshooting and doesn't seem like it should be that much of an ask.
Stuart_Smiles
the Meraki support team can set MTU on all devices in your setup, but you can't change it - has to be a call with them.
