Search instead for
change mtu on wan interface
Hi, i have a problem with a new fiber connection that use a mtu lower.
For not change all the mtu size on the client it's possible change the size on tha wan on lan interface of mx80?
Thank
Best regards
Accepted Solutions
Re: change mtu on wan interface
Hello @Aondio_Carlo, Yes the MTU Size can be changed on the WAN interfaces. You'll have to open a support case with Meraki support (help>get help ). Tell Meraki support the desired MTU size and they can set it on your MX for you.
6 REPLIES 6
Hi, thank for answer. I have open a support cases and i wait the answer from them.
Thank
Hi all,
if an MX device needs to be replaced (RMA case), would the replacement device get the same MTU size setting that the broken one had configured (by Meraki Support)?
Or do we have to open a new case right after the device has actually been replaced?
Rgds, Andreas
I'm also interested in an answer to this question.
Can this also be done on a template ?
Ha, I would be so glad if I could configure it manually at all -- not to dream of a template...
