change hostname?
tantony
change hostname?
The hostname of my meraki is vpn.companyname.biz-(other characters).
is there a way to make it just vpn.companyname.biz
I like to use vpn.companyname.biz for the vpn connection instead of the long way if possible..
I know with Cisco ASA you can have it to vpn.companyname.biz if needed
What's the best way to connect to VPN?  Using the MX public IP or by host name?
I like to use a DNS name, so that when the IP address eventually changes you don't have to re-configured all the devices out there.
Why don't you just create a DNS entry in your main public domain pointing to your public IP address, as opposed to using the dynamic DNS Cisco Meraki one?
6 Replies 6
tantony
Thanks, question....
I have a static IP from my ISP, do I still need to be concerned about the IP address changing?  I still like the DNS name idea.
If you have a static IP - no.
Otherwise if you really want to, use a CNAME pointing to the dynamic DNS entry.
tantony
thanks for your help
Jeizzen
Static IP adress should never change from what the ISP gave.
Enabling the dynamic dns is very useful when you have a dynamic ip adress from your ISP.
Suresh_stp
What is differ between appliance name and host name on MX.   How can we assign the IP address either to appliance name or host name to monitor the device from internal monitoring tool which uses SNMP polling?
Currently we are just using Vlan IP for monitoring for Single MX setup , but in Dual MX setup , you can not monitor the health of second device as the Vlans LAN IP shared between both devices. ( Not the warm failover alert ) . How do Monitor the Second router online/offline status
