I am trying to block YouTube on all platform (PC, IOS and Android) in our network. I created ab with the following block URL Patterns:
Youtube.com
www.youtube.com
googlevideo.com
gvt1.com
r3---sn-ni5f-t8gz.gvt1.com
r2---sn-ni5f-t8gs.gvt1.com
ytimg.com
r3---sn-ni5f-t8gs.gvt1.com
s.youtube.com
ytimg.l.google.com
Any browser base in all platform was successfully blocked, however app on both IOS and Android continue to work. On occasion, the preview of video will not show up, but streaming still persists once the user selects any videos. Packet capturing showing block on the list of URL above but the app continues to work.
Has anyone successfully block youtube?
thank you
Nelson M
I have the same problem and layer 7 FW rules don't block mobile apps. I still haven't found the solution to this problem.
Simply, just create Layer 3 firewall rule into group policy You use for mobile devices and deny UDP:
#policy #protocol #destination #port
Deny UDP youtube.com 80
Deny UDP youtube.com 443
Mobile application use UDP protocol instead of TCP
Goran
This is the correct answer, a lot of apps use the new-ish QUIC protocol which uses UDP ports 80 and 443 which does not get picked up by the content filtering rules.
Once you have configured the recommended rules the QUIC traffic will get blocked by the Firewall, the app will then fall back to using traditional TLS/SSL which will be blocked by the content filtering rules.
I have tried this option, but users are still able to access Youtube on Mobile Phones. Is there something am missing?
Try to change in protocol Any instead of only UDP...
I just did that and it still doesn't work. 😔
First try to block
1. youtube.com
2. youtu.be
3. googlevideo.com
4. googleadservices.com
If this not working, check how is policy applied? its on specific vlan? what is target ? Best solution is to block Youtube first on Content Filtering->Category Blocking , also URL Filtering below -> Blocked Url list
youtube.com
googlevideo.com
Then make more policy into Group Policy to allow this cointent in Allow list URL patterns (Override) for youtu.be; youtube.com; googlevideo.com
I maybe need more contents to solve this...
Great, it has worked like a charm now. I added (youtu.be,googlevideo.com and googleadservices.com) to the list as you've suggested.
I have exactly the same issue but still cannot get it to work following the steps mentioned. YouTube is still enabled in android devices. Could you please post your complete config for this setup?
