anyconnect connectivity issue
AntoineBAK
Hello
i'm blocked at the first stage of anyconnect configuration
Basic config is made on my appliance, ddns hostname, no certificate, subnet generated for auto vpn
when i tried on my laptop to connect to the MX with anyconnect, i have the following message
Connection failed due to servor communication errors. Try to reestablish the connection.
Did I forgot a step in the configuration ?
thanks
8 Replies 8
Is your MX behind a NAT?
AntoineBAK
I can said that, behind an Orange personal livebox with only one public IP configured on the box. There is a private interconnection between by MX and the livebox. The MX need to be configured directly with a public IP right ?
Yes, it's correct. Can you see any log about Anyconnect on Meraki dashboard?
AntoineBAK
Yes
msg: AnyConnect server is shutting down
Currently, the MX is configured with a private IP, the box has only one Public IP
I guess if i modify with a public IP it should works well
Antoine
Have you checked the troubleshooting documentation?
https://documentation.meraki.com/MX/Client_VPN/AnyConnect_on_the_MX_Appliance/AnyConnect_Troubleshoo...
Did you turn off the system firewall or antivirus? Maybe they could be blocking something.
AntoineBAK
yes checked for it but didn't found my issue, i will check thanks
Well, It looks like an SSL error, could you check the message history on the Anyconnect?
