Z3 site to site download speed
Maximiliano
Recently my Z3 download speeds have taken a major hit - most noticeably today I was only getting about 3mbps while upload is a solid 50+.
I have fiber internet on both ends with plenty of speed. I've tried rebooting and hard rebooting the Z3 device with no improvement.
Site-to-Site VPN configured as Spoke with Hub being my MX67 device at the office.  All traffic runs through the tunnel.  I've never noticed a speed issue until the last week or two and today being the worst.
Any ideas why my download speeds are struggling?
7 Replies 7
BlakeRichardson
Try rebooting the MX67. Have either had firmware updates recently?
If you bypass the site to site what speed does the Z3 get if accessing the internet directly?
I rebooted the MX67 and updated the firmware this afternoon - nothing seems to have changed.  No updates or other changes recently that I'm aware of.
Right now with site to site I'm getting like 2mbs download, if I bypass it I'm able to pull 80-100mbs.
Brash
Have there been any recent changes?
Things such as:
 - Firmware updates
 - Enabling additional security features such as IPS
 - Changes in network traffic
Do you have another device to test with to validate whether it's the Z3 or the ISP?
No changes that I'm aware of, other than I just ran a firmware upgrade on the MX67 in hopes it might fix things. (Without Success).
I have tested the following:
-PC hardwired to MX67 onsite = 100+mbs
-Hardwired to my local ISP router - 80-100mbs, wifi 50-60mbs
-Bypass site-to-site on Z3 and was able to pull 80-100mbs as well.
Maximiliano
Also of note - My upload speeds are great - 38-50mbs range.
Just the downloads that are struggling, and an issue that has been getting worse over the last week or two....  but today became unbearable.
If I connect via port or wifi to a VLAN outside of the site-to-site I get great connection speeds.
It seems somewhere in the site-to-site tunnel my download is getting throttled down hard.
Maximiliano
Update - Meraki Support helped me troubleshoot some more items today and did some backend (non-client facing) items.  The CPU is running up to 100% usage and seems to be a hardware problem.  They have offered to replace the device as the next step as there may not be a solution.
