Wireless range of MX64W or MX67W
Bob283
Does anyone know the generic range for the wireless capability for the MX64W or MX67W?  I found that the regular range for a MR product is 100 meters, but I can't find anything about the MX wireless-integrated products.
KarstenI
There is no exact range, also not for the MR-range. It all depends on your environment. But at least when I was using the internal wireless of the MX64W, it was not that good as I was hoping. This, together with the fact that the MX/Z-wireless is quite limited and does not integrate with MR, I always plan for MXes without integrated wireless and add a small MR access point like the MR36 to the network.
KarstenI
@Bob283 as a rule of thumb I'd say in the same room, though you might be lucky and have more range if the walls are flimsy etc.
I'm with @cmr , I think of it as providing coverage in a room or the immediate space.  I don't think I'd like to push it more than 20m.
