Why CVE-2016-7189 vulnerability in MS Edge is not reported by MX67 ?
FrederiqueC
Greetings,
I am receiving alarms from the border FW (Stormshield SN) to inform that packets coming from the meraki MX (used as internal FW, with Advanced Security License) are blocked because of CVE-2016-7189 vulnerability in MS Edge. The Meraki is performing NAT and because of NAT, I am not able to detect which end user is using an internet browser which is not up to date.
Which leads me to that question : how come that this vulnerability has not been flagged by the Meraki beforehand  ?
Thank you for sharing your knowledge on this matter.
Frederique
100% of my clients use the security ruleset.
This is the definition of each ruleset so you can determine which CVEs are included.
https://documentation.meraki.com/MX/Content_Filtering_and_Threat_Protection/Threat_Protection#Config...
CptnCrnch
Hi Frederique,
MX could catch this one by using the IPS. Do you have this enabled? If so, which ruleset is enabled?
FrederiqueC
Hi CptnCrnch.
Yes, IPS is enabled and the ruleset is set to "Balanced".
Actually I've checked the snort trule list, and I am not sure if there is one for this particular vulnerability. Do you think we should try with "security" ruleset even if connectivity is essential to our organisation ?
F.
