Client VPN fixed IP
jay_b
Client VPN fixed IP
Is there way to fix IP for client VPN?
I am trying to restrict one contractor who is using our client VPN. I only want to communicate that user to only 1 VLAN and block others. I think it would be easy If I can fix IP for client vpn user.
If there is any other way I would be happy to listen your ideas. TIA
I would do what @ww suggests.  I believe RADIUS can hand out a client IP address attribute (never tested it myself).
jay_b
@ww  and @PhilipDAth  that did the magic. Thank you.
