Whitelisting a Client from the Firewall using a Group Policy
Patumusiime
Does anyone know how I can exclude a client(s) from the firewall? I have created a group policy that is excluded from the firewall and then added clients using their MAC addresses and assigned them to the whitelisted group policy, however the firewall still blocks those clients. Group_policy.pngClients.pngPatrick.png
Have you tried the default Allow List?
6 Replies 6
Did you follow this steps, for example did the client reconnect the network?
https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Troubleshooting_Gr...
Yes I did. The clients have disconnected and re-connected to the network several times.
Brash
This config is correct.
That client should be whitelisted from all firewall rules.
Well, for some reason it doesn't seem to working as it should.
You dont have gp attacher to a vlan?
What is your l3 fw rule at the moment?
How do you verify its not working when the gp is attached
