What will happen to my device if TRIAL expires?
MauroF
What will happen to my device if my TRIAL expires?
1) it shuts the whole organization?
2) it shuts only the devices included in the trial?
3) another....?
In this case, the device licensing expires and only the devices that are unlicensed will stop working.
6 Replies 6
Shubh3738
Hi @MauroF
it will continue to run as per normal when your license expires. (You get a 30 day grace period to be out of license compliance.) You'll need to update/apply a license within this grace period otherwise at the end of the 30 days you'll organization will be disabled and the appliance will stop "Working".
LINK
MauroF
So you are telling me that After the end of the trial ive got another 30 days? 60 days in total from the moment i apply the Trial?
This rule does not apply to the trial license.
MauroF
ok so that means that after my trial expires (including per example a MX95)  only the MX95 will stop working,Correct?
You are correct.
