What is the shape of Meraki Mx64w signal? Is it spherical?
Karlo_nico23
Is the signal of Meraki Mx with wireless capabilities spherical? Does the same goes for MR?
3 REPLIES 3
BlakeRichardson
@Karlo_nico23  They come with an Omni-directional antenna in the box.
NolanHerring
If the access point has an 'E' at the end, it means external. For example MR42E, which allows you to use an external antenna (directional for example). Otherwise, all of the antenna within the Meraki lineup are internal omnidirectional (gain might vary per model). You can find their antenna pattern and gain information on the datasheet for the specific model your looking at.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
For the MR series the antenna patterns are in the datasheets. As @NolanHerring said, for -E access points it'll be in the datasheet of the antenna.
For the MX I haven't seen antenna patterns yet, but I'd expect it to be more like a somewhat flattened sphere. In the up and down directions the signal will likely travel less far (assuming the antenna's are pointing upwards).
