cheers! its very helpful, but im still not quite sure how I asses what load our devices are under.
First of all, the doc states maximum recommended values for each feature - but is that if that's the only feature in use? Can a device cope if its doing EVERYTHING near maximum values?
Also, how do I tell what our MX's are actually doing?
For example -
Flow and Session Data
It is important to understand the number of flows, or open sessions, supported by each appliance. For purposes of sizing, a flow is any transmission on an open socket within the last 5 minutes. Note that this is not a recommended flow capacity number, but instead these values are to be maximums.
MX-Series
| MX67 | MX68 | MX75 | MX85 | MX95 | MX105 | MX250 | MX450 |
Maximum Concurrent Sessions | 25,000 | 25,000 | 50,000 | 125,000 | 200,000 | 250,000 | 500,000 | 1,000,000 |
So it seems we can handle 500,000 "flows" in 5 min. Great, but are we operating close to that? over it?, no where near?
The nearest info I can find is in "traffic analytics" which can only give me a 2 hour timeframe and divides the flows up per application.
I could export to CSV to combine the flows for a total over 2 hours and get SOME idea but its not exactly precise is it?
Are there other performance/activity tools im missing somewhere? Would the MX alert if it was getting over-worked?
cheers.
