We have cuts in VoIP
CBM
We have cuts in VoIP. We have MX64 and MX84 in our offices. We have Cisco Call Manager. We suffer a lot of cuts in calls, provider that configure Call Manager has testing all and they have found a lot of icmp traffic from all MXs to Call Manager.
I have a doubt, is it a normal behavior that MXs send a lot of icmp traffic against Call Manager servers?
Any idea is welcome 🙂
6 Replies 6
CptnCrnch
Well, what kind(s) of ICMP? ICMP could also be UDP port unreachable when traffic is blocked... .:)
CBM
Provider see a lot of pings from MXs.
CptnCrnch
Because MX does Health Checks to the outside. I‘d be very surprised of that is related to your problem.
To keep things going forward: have you read our questions / suggestions? What about these?
GreenMan
Is your setup configured to use Insight VoIP Health?   https://documentation.meraki.com/MI/MI_VoIP_Health
MXs use ICMP for this monitoring.
GIdenJoe
If you have the call manager IP as uplink test IP or if you are using VoIP health then yes there would be alot of icmp originating from the MX.
Else you might capture at the LAN side of the MX'es if you see the icmp echoes coming from an internal device to the call manager IP.
IT_Magician
Check out my video on building high quality VoIP rules in the MX. Also in each MX, go to SD WAN & traffic shaping and add the public facing IP of your call manager server to check if packet loss is happening on the ISP WAN side.
https://www.youtube.com/watch?v=G57e4oQsHaw
