Ways to limit certain VPN users
Justfixit
I just found out that you can’t setup VPN client users with different permissions to LAN and VLANS.  Does anyone have workaround?  I am trying to have one user login and be able to see only a certain VLAN assets; while another user can have full access to the entire LAN.
3 REPLIES 3
perrosenlind
I'm using a "black hole" setup together with Group polcies to solve this. This is what I've done:
  • Isolate the connectivity from the VPN-client subnet to none or internet only (if you are using a full tunnel.)
  • Create a group policy
    • Add "override" priviliges to this group that matches your conditions
Note that when you use this type of setup you need to administer all incomming connections. I haven't tried this with LDAP integration module, only with radius which doesn't support mapping of users into groups in this case.
How did you "Isolate the connectivity from the VPN-client subnet to none" ?
I denied traffic to any from the VPN subnet.
