Warm Spare / Add secondary uplink
suneq
Hi guys,
I have a topology like this:
  • MX-1 is the primary appliance, MX-1 is connected to both ISP1 and ISP2 routers
  • MX-2 is the spare appliance, MX-2 is connected to both ISP1 and ISP2 routers
  • The ports Internet 1 of MX-1 and MX-2 are already configured and are operational
  • The ports Internet 2 of MX-1 and MX-2 are not configured yet (ISP2 did not provide the public IPs)
Now I've just received the public IPs from the ISP2 and wanted to configure the ports Internet 2 of both MX. I configured them in:
  • Appliance status > Uplink
  • Spare status > Uplink
I configured all IPs and saved the configuration but nothing displayed :
When I clicked on the pencil icon, I could see all the parameters that I configured.
I checked the ARP table but did not found any entries for Internet 2.
I learned from https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair
that "Dashboard configuration should always be performed before the Secondary MX is physically connected to the network."
Does it explain the issue that I have? What should I do now to bring up the Internet 2 ports?
Many thanks.
@suneq are the lights on on the WAN ports?
If they are, try plugging a PC into the cable currently in a WAN2 port, set the IP to the same as you have set on the MX and see if you get internet access.
3 REPLIES 3
KarstenI
When the configured IP-settings are not visible, then the MX can not use them to reach the dashboard. As already mentioned, first make sure with a PC that these IPs are actually working.
suneq
Hi @cmr , hi @KarstenI
You are totally right, the WAN configuration is visible as soon as the ISP fixes their connectivity issue.
I did not have physical access to the device so it took a while to have someone to test.
Thanks for your great help.
