- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Wan configuration not appear in the uplink tab
I don't find the WAN IP configuration in the uplink tab of my MX84. I have two MX84 in warm spare topology.
I don't understand why i can't see the WAN configuration here. I someone can help me
Thanks you
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The appliance status page is part of the "Monitor" side of the Security & SD-WAN menu. So information on the pages in that column is only relevant when the devices are online. Hence this behavior is to be expected if the devices never connected to the dashboard.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Uhhh... That doesn't look right. A call to support might be in order here.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Are the MX appliances actually online with a white light on the front?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
They never connect to the Dashboard for the moment, I prepare the configuration for a future installation on site.
This can impact the WAN configuration ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks you all for your response,
I will connect my MX to check if the WAN configuration appear.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Cool, so did you have any helpful advice besides "you're looking in the wrong place". If this is the monitor only place, then where do you go? You go to mx.meraki.com to do the initial IP config, then you add it to the network from the cloud section. So if this doesn't help, what does?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@motobeau you are replying to a post from 4.5 years ago. Do you have an issue and if so please start your own post.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I’m fully aware of when the thread was created, thanks 🙄 my response is valid and stands. Don’t try to force speech on me
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You might have to reboot the HA several time until they sync correctly.
