WMI error
WMI error
what are the possible reason for getting the WMI error in meraki mx84 Active Directory intergration with Windows Server 2008r2.
if possible, provide a step by step solution.
3 REPLIES 3
Re: WMI error
Hi @Kieshan did the Meraki documentation allow you to make any progress?
https://documentation.meraki.com/zGeneral_Administration/Tools_and_Troubleshooting/Active_Directory_...
If not, or the documentation process doesn't apply or provide any clues, I'd suggest opening a case with Meraki Support.
Re: WMI error
did not solved. Through the event viewer, the authentication successful. I will open a case for further assist
Re: WMI error
I have opened a case, so awaiting for Meraki response. Once the issue is resolved, I will share the cause of it.
