Access Point
DUITMAN
Access Point
Hello Everyone,
Recently I just set up the Meraki 67 X. I've been trying to connect to the http://setup.meraki.com/ web but it says I can't because I'm not connected to the access point. The thing is I'm on the same network so i'm stuck for right now. If anyone can help it'll be appreciated.
Try to access directly by the IP that the MX is configured.
https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Using_the_Cisco_Me...
  • MX - (varies)
    Most MX models have a dedicated management port used to access the local status page. In addition, the local status page is accessible at the MX's LAN IP address for all models.
    By default, MX devices run DHCP. Once the client is connected to a LAN interface of the MX, find the client's IP address and default gateway, then open the default gateway address in a web browser.
Note: If the MX is in passthrough mode and its uplink is on a subnet that overlaps with a remote subnet over VPN, either the MX will need to be temporarily removed from VPN to be accessed locally or the local status page can only be accessed via VPN.
2 Replies 2
  • MX - (varies)
Try connecting to:
http://my.meraki.com/
