WMI error
Kieshan
WMI error
what are the possible reason for getting the WMI error in meraki mx84 Active Directory intergration with Windows Server 2008r2.
if possible, provide a step by step solution.
9 REPLIES 9
MerakiDave
Hi @Kieshan did the Meraki documentation allow you to make any progress?
https://documentation.meraki.com/zGeneral_Administration/Tools_and_Troubleshooting/Active_Directory_...
If not, or the documentation process doesn't apply or provide any clues, I'd suggest opening a case with Meraki Support.
did not solved. Through the event viewer, the authentication successful. I will open a case for further assist
I have opened a case, so awaiting for Meraki response. Once the issue is resolved, I will share the cause of it.
Did you happen to get this resolved.  I am having the same issues
HI,
Yes I found a workaround  since Meraki support could not help me out further. Install IIS role on your DC and create the certificate from there. This cleared the WMI error for me on the dashboard and was able to see my AD.
Hope it solves yours also.
HP
Hi Kieshan. Are you using any specific IIS configuration? How did that tie into WMI error?
Kieshan
It is the default configuration on the IIS. It has solved the certificate verify issue
Did you have to create a certificate or just installing the IIS service fixed the problem?
Thank you
Orobio
thanks for this recommendation, resolve my problem 👍
