what are the possible reason for getting the WMI error in meraki mx84 Active Directory intergration with Windows Server 2008r2.
if possible, provide a step by step solution.
Hi @Kieshan did the Meraki documentation allow you to make any progress?
https://documentation.meraki.com/zGeneral_Administration/Tools_and_Troubleshooting/Active_Directory_...
If not, or the documentation process doesn't apply or provide any clues, I'd suggest opening a case with Meraki Support.
I have opened a case, so awaiting for Meraki response. Once the issue is resolved, I will share the cause of it.
Did you happen to get this resolved. I am having the same issues
HI,
Yes I found a workaround since Meraki support could not help me out further. Install IIS role on your DC and create the certificate from there. This cleared the WMI error for me on the dashboard and was able to see my AD.
Hope it solves yours also.
Hi Kieshan. Are you using any specific IIS configuration? How did that tie into WMI error?
It is the default configuration on the IIS. It has solved the certificate verify issue
Did you have to create a certificate or just installing the IIS service fixed the problem?
Thank you
thanks for this recommendation, resolve my problem 👍
