WAN uplink shutdown
guitb
WAN uplink shutdown
In the event of an intentional shutdown of both Meraki MX WAN interfaces, leading to a loss of cloud connectivity, are there any automatic security mechanisms to revert to the previous configuration and restore the connection?
If not, what steps are needed to resolve this?
6 Replies 6
Meraki MX devices do not have automatic security mechanisms to revert to the previous configuration and restore the connection if both WAN interfaces are intentionally shut down.
For good practice, it is best to have a pair of MXs in HA.
If an intentional shutdown is performed manually, there is not much you can do other than access the MX locally and reactivate the interfaces.
To prevent this from happening, only those who really need access can do so.
guitb
How do you locally access the meraki MX?
Via Device Local Status Page.
https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Using_the_Cisco_Me...
DarrenOC
@guitb , never tried it.  You would think the system would alert you to the dangers of doing so like the warning you get when configuring an uplink on the switches.
Samir771
Unfortunately if you disable the interface manually the information in the document does not apply.
