WAN Optimization - Web/Byte Caching
Vikesh-jhb
Can anyone confirm if the MX does Caching?
Web caching is almost completely pointless these days.
However if you really want to use this feature - and I don't think you should - then you need to use the MX models that have a hard drive built in such as the MX84.
Refer to this table and the "Web caching" column.
https://meraki.cisco.com/products/appliances/mx84#compare
2 REPLIES 2
Great Thanks.
