- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
WAN Failing PCI compliance - http on MX100
I ran a PCI scan and the WAN interfaces are both coming up as failed with the following:
Reason | The remote web server is affected by a cross site scripting vulnerability. |
PCI details | medium |
Port | 80 / tcp / www |
Host name | - |
Host OS | - |
Result URL : http: x . x . x . x .hfc.comcastbusiness.net/third_party/jquery/jquery-1.10.1.min.js Installed version : 1.10.1 Fixed version : 1.12.0 |
2. Web Server HTTP Header Information Disclosure
80 / tcp / www
Host OS | - |
Result Server type : lighttpd Server version : 1.4.39 Source : lighttpd/1.4.39 |
Solution | Modify the HTTP headers of the web server to not disclose detailed information about the underlying web server. |
Anyone know how to resolve these two issues??
I've searched with no answers.
Doug
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
AHHH HA...
I figured it out. (like I said this, is a completely new setup)
SO I went to the Firewall configuration page in my Meraki mgmt console / and I found under
Security appliance services: Web (local status & configuration) ANY / see screenshot
I changed it to None.. waited a minute and tested again...
BOOM! No More WAN Meraki web config page!!!
I hope this helps someone else in the future.
Doug
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This means you are NAT'ing port 80 on the WAN IP through to an internal server - and that server has the vulnerabilities.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello Phillip, thanks for taking time to respond.
When I put in the WAN IP's that are failing... the Meraki web interface comes up.
I have no NAT's no VPN .. it's a new install. I'm testing the PCI scans before I switch over to the new Meraki firewalls.
Is there a place to disable that somewhere??
Please advise/
Doug
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
How could the Meraki web interface come up if you haven't switched over to them?
Is this some kind of internal scan you are running?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
my sonicwalls are running production; I have setup all the new Meraki gear along side the current infrastructure, and configured the Meraki MX100 WAN ports using additional IP's we have.
I can hit that Meraki MX100 config webpages from the outside using the WAN IP and teamviewer from my home
no the PCI scan is from pcicompliancemanager . com
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
**MORE INFO**
I reviewed my MX100s and note: I have 2 MX100s in passive HA mode..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
AHHH HA...
Doug
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Philip,
Even i'm facing the same issue as @DouggieFresh. I'm connected to my home broadband and when I try to http://<Meraki_Public_IP>/#connection , I can retrieve Hostname, Network Name, Hardware address(MAC), model, etc
Any help to overcome this vulnerability will be really helpful.
Thanks,
L
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You do exactly what @DouggieFresh did, and go to Firewall configuration/Security Services and either disable the local status page or limit the IP addresses further than it can be accessed from.
