Virtual instances on security appliance?
Can any of Meraki security appliance be partitioned into multiple virtual instances, similar to security contexts on Cisco ASA?
Accepted Solutions
Re: Virtual instances on security appliance?
6 REPLIES 6
I believe the closest you'll get to this on the MX is VLANs and Policies.
Hi Adam,
Thanks for your reply but I'm after a yes or no answer form a Meraki representative.
@Kristof wrote:
Hi Adam,
We can only consider @PhilipDAth a pseudo-Meraki representative.  But I still agree with his final answer.  'No'
JHO
Definitely a big NO, this is something that may come out in the future though.
Thank you!
