I believe the closest you'll get to this on the MX is VLANs and Policies.
Adam R MS | CISSP, CISM, VCP, MCITP, CCNP, ITILv3, CMNO If this was helpful click the Kudo button below If my reply solved your issue, please mark it as a solution.
Thanks for your reply but I'm after a yes or no answer form a Meraki representative.
We can only consider @PhilipDAth a pseudo-Meraki representative. But I still agree with his final answer. 'No'
