VRRP transition logs
Wendy2
We have a site with 2 x MX in HA.  We are seeing  VRRP transition logs. The MX security appliances are frequently swapping between Master and Passive.
VRRP transition old_mode
detect prio 235
old_prio 235
elector_state master
last_state_change_reason master_down_timer
We are seeing MAC_flap logs on our Cisco switch.  No impact has been reported, but this is the only site we're seeing these errors on.  MX each have a lan port and wan port connected into separate switches in a stack.
Haven't been able to figure this out yet.
18 Replies 18
How is your topology? This is usually due to an error in the topology design.
Wendy2
Thank you for your response.  MX_01 : Lan port into Cisco switch 1 trunk port.  WAN into internet router.  MX_02 : Lan port into Cisco switch 2 trunk port. This is a switch stack.
Packet capture is showing a loop between the VLAN Interface IP's
Checked spanning tree, and no errors.  This site is setup identically to another site with no MAC_flaps
Does the trunk port include VLAN1?
Wendy2
No, just the vlans setup on the MX
Is the Cisco switch stack the root bridge for all VLANs that are in the trunk?
Are there other switches in the LAN?
Wendy2
Yes, the core stack is the root bridge for all VLANS in the trunk.  We have two other access switches in the topology.  There is no impact to production as a result of this mac_flap so far.
As mentioned elsewhere, we did have the same for several firmware versions and a switch to DAC cables fixed it. Do you have spare SFP+ ports on the switches?
Just to remind you that it is recommended that STP is enabled to avoid looping.
https://documentation.meraki.com/MX/Networks_and_Routing/MX_Layer_2_Functionality
Is this site running the same firmware versions as the other sites without issues?
Wendy2
Yes, it's identical to another site with the same topology.  MX_105 running the same versions 18.107.2
Are they MX250s and what firmware version are they running.  We had this issue with busy MX250s in concentrator mode where we used GLC-T modules in the WAN ports running at 1Gb.  Once we changed over to 10Gb DAC cables the transitions went away.
Wendy2
Thanks for the reply.  MX_105 running the same versions 18.107.2.  We're using ethernet ports
Are the Cisco switches running STP?
I'd upgrade to 18.107.10 at least and ideally a newer version.
How loaded are the MXs, more or less than the other site where there aren't errors?
Wendy2
The WAN ports lights are orange?  Is this correct?
Orange normally indicates that they are not running at the fastest port speed.  What does the dashboard report?
Wendy2
Dashboard says 1Gbps full duplex
Wondering if this issue is due to faulty physical cabling?
VRRP is over the LAN ports and the logs don't seem to show WAN down, unless that is also in there?
Wendy2
Site is fully up and functioning.  No issue reported about from the MAC_flaps I have noticed.  WAN is a separate thing, I agree
