Hello!
I use a couple Mikrotik switches in SwOS mode, basically as switches not routers for my 10GbE traffic. Theres 2 of them and theyre assigned 192.168.3.2 and .3, respectively. I have a MX65 for my router and am overseas for a while. I like to log into the switches just to check on things and today I ran a firmware update from the web OS interface on Safari for iPhone using the Meraki VPN. Works great over iPhone. My MacBook Pro, however, with identical settings, authenticates and connects successfully and it can pull up pages like CNN or Apple.com or Meraki dashboard, but it wont pull up the SwOS web config page when I use the direct IP in the address bar. Again, same exact creds on iPhone, authentication works fine on both, general web access works through both, but on the iPhone I can use the IP of the switch and on the Mac I cant. Just sits there with a stalled progress bar part of the way across the screen. No error. Thoughts?
