VPN tunnel connectivity change
ratnesh
Hi All,
Need your help in solving VPN Tunnel Connectivity Change happen frequently .
May 6 12:06:58 VPN tunnel connectivity changevpn_type: site-to-site, peer_contact: X.X.X.X:PORT, connectivity: true
May 6 12:06:51 VPN tunnel connectivity changevpn_type: site-to-site, peer_contact: X.X.X.X:PORT, connectivity: true
May 6 12:05:07 VPN tunnel connectivity changevpn_type: site-to-site, peer_contact: X.X.X.X:PORT, connectivity: true
May 6 12:05:02 VPN tunnel connectivity changevpn_type: site-to-site, peer_contact: X.X.X.X:PORT, connectivity: true
May 6 11:33:09 VPN tunnel connectivity changevpn_type: site-to-site, peer_contact: X.X.X.X:PORT, connectivity: false
May 6 11:32:48 VPN tunnel connectivity changevpn_type: site-to-site, peer_contact: X.X.X.X:PORT, connectivity: false
May 6 11:32:43 VPN tunnel connectivity changevpn_type: site-to-site, peer_contact: X.X.X.X:PORT, connectivity: false
5 Replies 5
kordm
Is one of the VPN endpoints behind a NAT? You might need to configure your gateway/router in bridge mode to bypass NAT before it gets to your MX.
Are there any known issues for the internet connection at either end? I have a lot of VPN drops at one of my sites, but that internet connection is wireless and not reliable.
DaveMunger
Did you find the issue? I have the same problem on my side.
Txs
Dave
JesseLeiker
I am in midst of converting several sites to Meraki s2s and 5 sites in; i have this happeneing every 2-5 minutes since-turn-up last week. No noticeable (reported) impact to users...but don’t like it.  I’m Thinking about looking at the circuit first?
whistleblower
Hi to all,
I´m also noticing that "problem" in one of my networks but till now I could`nt find a problem on the physical lines or cpe-routers 😞
could probably the NAT- which is done on a 3rd Party Firewall before the 1-armed-concentrator be the problem? if so, what`s the best way I can troubeshoot that?
SumithP
I got Static Public IP Address from ISP for one of my location and the issue got resolved.
