VPN traffic over WAN2
JPaul
Hello
I have a question about Non Meraki VPN peers over WAN2. We currently have a solution in place with a static IP but is only giving us 5mbps throughput, we have had some one out to test a new solution that will give us more than 4x the speed but no static. Can we use the better connection for accessing all data including what’s over the VPN to use the better speed on WAN1 or will all vpn traffic run over the rubbish WAN2?
If you are using WAN2 to establish S2S VPN, all traffic to a specific destination will be over S2S VPN established over WAN2.
7 Replies 7
Yes, you can configure to establish the VPN on another WAN.
JPaul
Thank you but will like file access use WAN2 to access the file or WAN1?
Sorry, I don't understand. 😅
Do you want to use WAN2 to establish S2S VPN and WAN 1 for Internet access?
Or did I get it wrong?
But for example. If you are using WAN2 to establish S2S VPN, all traffic to a specific destination will be over S2S VPN established over WAN2.
I don't know if I was clear.
JPaul
Hi basically want I want to know is if a file share is accessed over s2s will it be accessed and opened on WAN2 or WAN1
JPaul
Thank you this is what I thought.
