VPN non meraki and client VPN
sebvasseur
i have one site (1) with MX with a VPN non meraki working for LAN(1),  a second site (2) with site to site VPN between (1) and (2) and with access for VPN client (2) , with vpn client(2)  i see LAN (1), LAN(2) but unable to use the non meraki VPN on site (1).
in route table from site (1) i see the ip address from vpn client(2)
should i add a vlan in site 2 with ip from VPN non meraki and add a route to mx (1)  and disable access to lan(2) in the non meraki VPN ???
DensyoV
The routes learned from auto-VPN (Meraki to Meraki) cannot be advertised to a non-Meraki peer. You need to configure a separate IPsec tunnel pointed to site 2 if you would like that VLANs on that site to access the resources across the non-Meraki VPN peer.
Hope this helps.
Please hit kudos if you found this post helpful and/or click "accept as solution" if this solved your problem.
1 REPLY 1
DensyoV
Hope this helps.
