VPN disconnections
ReyesPolanco
VPN disconnections
Hello!
Here again, I'm resolving an issue I'm having with a Meraki VPN with SonicWall. In case this has happened to anyone else and they can help me.
A site-to-site VPN was set up between Meraki and SonicWall, however, the VPN disconnected. That is, despite the Meraki dashboard showing the status, no traffic was passing through. The solution was to turn the VPN off and on again on the SonicWall side.
Do you think this is due to a Phase 1 and Phase 2 configuration issue?
ReyesPolanco
Thank you all for your great support. We solved the problem using Ikev1 and the following values ​​in phases 1 and 2
14 Replies 14
Try to increase the lifetime (28800) of phase 1, it is not good practice to leave both phase 1 and phase 2 with the same lifetime.
https://www.sonicwall.com/medialibrary/docs/tech-alliance/IntegrationGuide_CiscoMeraki.pdf
ReyesPolanco
Initially, the lifetime was set to 28800, but it was lowered to see if that would change anything, but it's still present. I'm going to set the phase 1 value to 28800. Thanks!
Is DPD enabled on SonicWall?
If DPD is not enabled or not functioning properly, the SonicWall may not detect that the Meraki side is idle or unreachable.
ReyesPolanco
Yes its correct. Do you consider it important to disable it?
On the contrary, it states that it is necessary to have DPD. In Meraki, it is already enabled by default.
ReyesPolanco
It is necessary to mention that this configuration was made based on a document provided by both vendors Meraki-Sonic, which is why it seems strange to me that these problems occur.Captura de pantalla 2025-06-02 a la(s) 10.55.34 a.m..png
Have you tried enabling dead peer detection for idle VPN sessions?
ReyesPolanco
No, but I'll take it as a test with the client, hoping it will solve the problem.
Grizwald
What do the logs show on either side for the Disconnect reason?  Is there any attempt to re-establish from the Meraki end? Are Security Associations formed on the Meraki end once the tunnel attempts to reestablish?
ReyesPolanco
The problem is that the tunnel never shows up. It's visible from above in Meraki, but when attempting to connect between segments, it fails. There are no logs or anything indicating a problem, and the workaround is to turn the VPN on and off on the Sonic side.
DarrenOC
What happens if you generate traffic over the VPN ie PING?  Does the tunnel re-establish?
ReyesPolanco
No, the problem is that for the Meraki dashboard it is always active but without passing traffic
AlexL1
Hi ReyesPolanco,
I hope your day is going well.
Please, find our detail guide - MX to SonicWall Site-to-Site VPN - https://documentation.meraki.com/MX/Site-to-site_VPN/MX_to_Sonicwall_Site-to-Site_VPN_Setup
SonicWall also has their own integration guide for Cisco Meraki - https://www.sonicwall.com/medialibrary/docs/tech-alliance/IntegrationGuide_CiscoMeraki.pdf
Troubleshooting:
STEP 1 - Generate interesting traffic - from a device in MX site constantly pinging another device on the Remote Peer (SonicWall) side.
STEP 2 - Start taking PCAPs:
  • On the MX primary uplink Internet interface - filter for "ip.addr == <public IP address SonicWall> && (isakmp || esp)" --> Do you see Bi-directional traffic on UDP 500 and/or UDP 4500?
  • MX IPsec VPN interface - filter for "ip.addrr==<source IP device MX site> and ip.addrr==<dest IP SonicWall site>"
STEP 3 - What does Security & SD-WAN --> VPN Status --> Non-Meraki VPN section shows - green dot, red dot, orange dot?
STEP 4 - What does Event logs are showing on the Dashboard?
  • Network-wide > Monitor > Event log. Select the All Non-Meraki / Client VPN event log type as the sole Event type include option and click on the search button
STEP 5 - What does the logs on the Remote Peer - SonicWall shows? Can you take PCAPs on that side as well?
If you need any assistance, please feel free to create a case with Meraki Support Team and arrange a Live Troubleshooting session 🙂
ReyesPolanco
