I have been looking into this myself, and from what I can find those vpn services use certificate based vpn, which is not supported on Meraki (from what I have found).
If it’s a feature you would like to see, use the Make A Wish button, speak with your local Meraki Rep
LinkedIn :::
https://blog.rhbirkelund.dk/Like what you see? - Give a Kudo ## Did it answer your question? - Mark it as a Solution
🙂All code examples are provided as is. Responsibility for Code execution lies solely your own.
