VPN Mode Static Routes not installing on Site-to-Site Peers
MitchyB
Having an issue where 4 out of 5 static routes on an MX67 (Firmware 19.1.11), enabled with VPN Mode turned on, show up as unknown on every other auto-VPN connected MX67 or Z4 that we have in our network (all running the latest firmware), and aren't reachable. 10.246.1.0/24 is green and reachable, but the other 4 are showing up as "None/( - ) the status is unknown". This is the default state while waiting for the status of a route.". There are no other better priority routes in the routing table.
I can't quite figure out why that's happening, any ideas? Sanitised screenshots attached. Haven't rebooted the appliance yet.
Thanks in advance.
15 Replies 15
Mloraditch
I've seen weirdness like this before and rebooting and/or disabling and reenabling VPN usually fixed it. Perhaps once or twice support had to do something. I won't say it's a common issue, but I've seen it enough over the years.
This may not be easy if there are dependent dhcp scopes, fw rules, etc, but you can also try removing and readding the route.
MitchyB
Thanks, nothing business critical so will give that a try. The MX in question was upgraded to 19.1.11 only 7 days ago but I can disable/reboot everything and let it rebuild from the ground up, thanks.
RWelch
I would focus on the next hop - that is likely where the issues resides.
MitchyB
Sorry I forgot to mention that these networks are reachable - for example if I give my Z4 an exit hub of this MX67 then the local routes all work.
RWelch
Are all of these devices in the same ORG (AutoVPN)?  Or are they in separate organizations where you require IPsec VPN peers?
Site-to-Site VPN Settings
MitchyB
All within the same Org using AutoVPN, yes.
RWelch
The MX67 is Hub and all other devices are spokes?
MitchyB
Some are spokes, some are other hubs in other DCs, all show the same "-" next to the route in the table.
RWelch
Static routes are generally not required for typical AutoVPN-connected subnets.
RWelch
When using Meraki S2S (AutoVPN) the routing table typically shows:
Meraki VPN: VLAN
Your route table is showing Meraki VPN: Static Routes
MitchyB
The gateway for each subnet isn't on the MX itself, it's on the core switch infrastructure downstream of the MX, so we have these static routes in place. Next hop is the SVI on the core switch, on a shared transit network (the 10.255.252.22 IP)
RWelch
Site-to-Site VPN Troubleshooting
If any of those four subnets overlap with ,local VLANs on the MX, other static routes or remote VPN subnets, Meraki will suppress the advertisement to avoid conflicts.
MitchyB
No overlapping subnets to my knowledge, but it's always worth a check, thanks.
This smells like a firmware bug.  Are you running current stable or better firmware?
