VPN MX ---> Fortigate Overlap network
MauroF
I have an issue during the creation of a VPN with a non-Meraki device: the counterpart's network (192.168.7.0) overlaps with my local network, and they cannot perform NAT on their Fortigate.
Is there something I can do to resolve this situation on my Meraki, considering my local network is directly connected to my MX?
5 Replies 5
jimmyt234
Re-IP your local network to avoid the subnet clash...
or ask them politely again to review if they can do a NAT on the tunnel on their FortiGate as they should be able to, having personally done so in the past on those firewalls.
Nothing other than changing the subnet. Why they can't configure NAT in their side?
MauroF
Im asking to configure a NAT FGT side.Lets see.. cause i cannot change Network IP for this client.
MauroF
is ther a way Ale, to nat private to private in Meraki? I mean....i need to NAT via VPN a private IP with another Private IP.
Nope, it's not possible on non-meraki peer VPN.
