First I have never worked with Meraki before but have the following requirements. I need to provide guest internet access at branch offices. The branch offices only have MPLS connections and no local internet breakout. For guest internet access a separate internet line is provisioned at HQ.
Branch MX firewalls can reach Meraki cloud platform for management using normal internet line routed over other firewall. I would like to build a separate IPSEC tunnel to the MX in HQ to provide internet guest access.
The Meraki firewall for guest at HQ has a public routable IP at WAN side and should also have an internal IP that is reachable over the MPLS to establish IPSEC tunnels between BRANCH and HQ.
I have read so fare that you can deploy MX in concentrator or routed mode. I guess I need to use routed mode. Can I use the auto VPN feature for this or should I use third party VPN.
I am not looking for a detailed technical approach but some direction on how to best approach this.
With the cloud management and auto-vpn I don't really now how this works.
RED LINE IPSEC, BLUE MGT for Meraki branch to cloud platform.
