I made an adjustment to a firewall that I had setup as a HUB in my S2S environment. This firewall had no users connected to it so I changed the hostname of the firewall. A couple of minutes later I started getting reports that users all over were not able to use the VPN, getting authentication errors and PPP server not responding from the other HUBS. Unsure as to what happened but knowing that it had something to do with the change I checked various settings and verified DNS information (still pointing to the other HUBS) and RADIUS servers, all were good, but the issue persisted. I ended up changing the firewall from a HUB to a SPOKE and that resolve the issue with one of my HUBS but not the other. I ended up removing the non-working HUB from the SPOKE list and the issue was resolved. As of right now, this firewall is still setup as a SPOKE and need it as a HUB.
Can someone tell me if and when I can change it back or if I have to use the old hostname that it was originally prior to the change.
I would also like to know how this could have happened where changing the hostname of this firewall would drop all other HUBS and deny VPN connections. Any information would be extremely helpful, thank you.
