VPN_Clients_A to Subnet_A and VPN_Clients_B to Subnet_B
rcpa0_en
Is there a way to only connect VPN_Clients_A to Subnet_A while VPN_Clients_B only connect to Subnet_B?  I have an MX84.
>I do not see how to bind a Client VPN Guest User to a specific Group policy.
You assign it the same as any other client.  You locate the VPN user in Network-Wide/Clients (after they have logged in one) and assign the group policy to them.,
7 Replies 7
It's a bit painful.
You'll need to create two group policies with firewall rules to match your requirements.
Then apply the group policy to the users as required.
rcpa0_en
Sorry, I didn't make it clear.  VPN_Clients_A and B are "Network-wide > (Client VPN Guest) Users" of "Security & SD_WAN > Client VPN", not each user's mobile/remote network devices.
rcpa0_en
The client identifier looks like a MAC address but does not match the MAC address of the iPhone, nor the DSL modem at the edge of my network before the ISP.  Where did it come from or how was it generated?
If the VPN Guest chooses to use a new device or move the device to a hotel room, will it generate a new Client ID or is the Client ID unique to the VPN Guest account used to login?
The client ID is related to the username.  It is always the same no matter what device the user is using.
rcpa0_en
Excellent! Thank you.
Although, why bother displaying the MAC address resembling Client ID when it should show the Client VPN's User ID?
