Rarely I have seen issue with shim drivers, as installed by antivirus or other VPN clients. Try uninstalling anything that looks like it could install something into the network stack. If it works slowly reinstall the bits of software one at a time. Sometimes the order that shim drivers get install is important.
Failing that, try seeing if there are any NIC driver updates (Ethernet and WiFi).
