VPN Client Connection Issue on Windows 10
SajidY
Just browsing
I'm using CISCO Meraki MX84 Firewall with all the required configurations to connect to it's VPN server (both at MX and client side i.e. Windows 10 VPN). But I have been un-successful in establishing a VPN connection.
I have been reading lots of articles about similar issues but none of them could help me troubleshoot the issue. It is also very strange that I can establish a VPN connection to the same using my Android phone without any problem.
Following message is received when I try to connect to VPN on Windows 10 computer:
The Windows Application log shows error:
CoId={E0A1B9A4-71CA-0002-1F6F-A3E0CA71D901}: The user SYSTEM dialed a connection named MyVPN which has failed. The error code returned on failure is 809.
Any help in resolving the issue will be highly appreciated. Thanks
7 Replies 7
MJH
SajidY
Just browsing
Thanks for your reply. Yes, I have already tried everything mentioned in the article but still can't find a success on the VPN issue.
ksumann
Had the same issue. After creating the registry key and rebooting the issue was resolved.
SajidY
Just browsing
I have already added the key but still get the same issue.
Have you installed any recent Windows updates? if yes try to uninstall the update.
Have you thought about using Anyconnect?
Use rasphone.exe to start the VPN.  It gives better diagnostics.
Basically - the configuration on your machine is probably wrong.  You can use this tool to create a powershell script to correctly re-create the VPN connection.
https://www.ifm.net.nz/cookbooks/meraki-client-vpn.html
SajidY
Just browsing
Thanks all, the issue has been resolved after removing antivirus. It had firewall blocking the ports.
