Hi
I have previously had my MX64 appliance running as a single lan with a radius SSID broadcasting.
The radius client is setup within NPS as 192.168.106.1.
I have since created 4 VLANS to seperate the network as per below.
Since adding these VLANS I noticed that clients could no longer connect to the RADIUS ssid. Upon looking at the logs I could see that the requests were coming into NPS and failing as the MX IP of VLAN 4 was not setup as a client within NPS.
If I add this radius works fine on client pc’s
My problem is my radius SSID is set to use VLAN 1 why does the the radius request come from the VLAN 4 MX IP?
Is it by design that the highest VLAN makes radius requests?
Any advice guidence why this is happening so I can understand will be much appreciated, if you need any further information from me please ask
Scott
