Using configuration from a 1921 router to configure an MX84 SDWAN
mcoomber
I've got a Cisco 1921 Series router and an SDWAN within my network.
The link from the service provider connects to the 1921 Series router and the router connects the SDWAN.
I want to take the 1921 router off the network.
Before doing so I want
  1. Can the configuration in the router be configured in the SDWAN
  2. Below is the configuration from the router. How can this be translated to the routing config in the SDWAN.
The aim to have the connection from the ISP directly connected to the SDWAN since its already configured as the default gateway and Firewall.
x.x.x.x 255.255.255.248
interface GigabitEthernet0/1
 ip address x.x.x.x 255.255.255.248
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/2
 ip address x.x.x.x 255.255.255.252
 ip nat outside
 duplex auto
 speed auto
ip tftp source-interface GigabitEthernet0/0.5
ip nat pool Pool-NAT-ISP1 x.x.x.x x.x.x.x netmask 255.255.255.252
ip nat pool Pool-NAT-ISP2 x.x.x.x x.x.x.x netmask 255.255.255.252
ip nat source static x.x.x.x x.x.x.x
ip nat inside source route-map ISP1 pool Pool-NAT-ISP1 overload
ip nat inside source route-map ISP2 pool Pool-NAT-ISP2 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1 x.x.x.x track 1
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/2 x.x.x.x track 2
ip access-list extended Internet
 permit ip 172.16.0.0 0.0.1.255 any
 permit ip 192.168.20.0 0.0.0.255 any
ip access-list extended RTR-SIP-REG
 permit ip host 172.20.0.2 any
nls resp-timeout 1
cpd cr-id 1
route-map ISP2 permit 10
 match ip address Internet
 match interface GigabitEthernet0/2
route-map ISP1 permit 10
 match interface GigabitEthernet0/1
no ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1 x.x.x.x x.x.x.x track 1
no ip nat inside source route-map ISP1 pool Pool-NAT-ISP1 overload
no ip nat pool Pool-NAT-ISP1 x.x.x.x x.x.x.x netmask 255.255.255.252
ip nat pool Pool-NAT-ISP1 x.x.x.x x.x.x.x netmask 255.255.255.248
You just need to configure your WAN interfaces with the IP that the operator is providing you. And for each of your internal networks you need to create an SVI in the MX.
Ideally, you should send a simple topology to be more accurate.
Configuration on the MX is relatively simple, you don't need to create NAT or ACL for it to be able to communicate with the internet.
6 Replies 6
Most settings can be translated for use on the MX.
You will see that at Meraki things are simpler, for example you don't need to do an outbound NAT for the internet, just configure the interface with the IP provided by the operator and plug the cable into the wan and it will work.
mcoomber
I have configured interface GigabitEthernet0/1 on the router to Port 2 on Meraki and interface GigabitEthernet0/2 on the router to Port 1 on the Meraki.
Without configuring NAT, do I need to configure the static routes and ACL? If so where in the Meraki do I do these configurations
Thanks for the support thus far.
It's a bit confusing what you want to do, can you illustrate it in a simple way?
https://documentation.meraki.com/MX/Networks_and_Routing/MX_Addressing_and_VLANs
mcoomber
I just want to configure the present configuration in the router to the MX 84.
So I want to know what configs in the router I need and which I can skip. Also which config Meraki corresponds with the config on the router.
Thanks.
mcoomber
Thanks very much for the support and guidance. Will revert to you tomorrow after configuration.
