Search instead for
User and Password for Cliente VPN
Hello!
I have a MX100 as Firwall. Two questions:
1. Can I force the vpn client password to be strong?
2. Can I force the user of vpn clients to change their password every so often?
Is there any way of doing this?
Thank you!
Accepted Solutions
Re: User and Password for Cliente VPN
Just to add to what @ChrisKemsley said. If you're using Meraki accounts the strong password setting can be found under the Security section in Organisation > Settings.
6 REPLIES 6
1. The client VPN password depends on what directory the client is authenticating against - i.e. AD or the Meraki Cloud. If you are storing user names / passwords in the cloud than you have the option to make the passwords for those users strong
2. By using Active Directory as the user directory that accounts will authenticate against, passwords and the policy around them, along with automated user creation / deletion amongst other benefits can be controlled by the directory servers.
Excellent! Thank you very much! this is what i Needed
Excellent! Thank you!
Thank you!
This section of the dashboard is for administrator accounts, but not for vpn clients accounts
Thank you! I think your answer is the best option for mi. Thank you!
