I was trying to bring up a network at a site where their ISP is an AT&T. They had a fiber router, ADIR0 with speeds of 20 mbps. When moving the connection from a cradlepoint to the Cisco Meraki MX-75 the LED light would go red. Meraki dashboard showed the device as offline and dhcp didn't seem to work. I consoled into the MX-75 and created a static route and the uplink came up for 30 minutes and went back down. I'm wondering if this is an arp problem or if I should try rebooting the AT&T managed router.
If you haven't done so already, I have found that when adding a site that has a static address, it's always good practice to reboot everything and then in steps bring up the ISP modem and then the appliance.
Yes, I think that is what I'm going to do on Monday. I think that the AT&T router is having ARP issues. It is probably looking for the MAC address for the Cradlepoint IBR1700. Rebooting the ISP modem will probably clear the ARP table.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_57948ddb321d9","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_57948ddb321d9_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_57948ddb321d9_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_57948ddb321d9_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_57948d597047e","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
