Unable to resolve the name using site to site VPN
HaniAbuelkhair4
I have two offices that I'm going to connect with a site-to-site VPN. I have two Meraki MX64's and have setup the site-to-site using Hub (Mesh) mode. I performed a test of the VPN it seemed to work well. I could ping between sites, and i can ping the windows server that is my DNS and shared folder server,  I am unable to ping the domain name or server name.
I have 4 sites on that site to site VPN group accessing the same shared folder with no issues, only this remote site i have the site to site VPN up and i can ping both sites with no issues and i can map the shared folder by IP but i need the domain controller to be reachable by name not IP.
I have configured the DNS server on the DHCP to point to that DNS server Custom nameservers similar to other location but again hostname is not resolving.
Any suggestions or ideas ?
You should not need WINs - so I won't tell you how to fix that one ...
All you should need is a DNS suffix on your machines to search within their own domain name.  You can configure this on Meraki DHCP by adding custom option 15, and filling in your AD internal domain name (like company.local).
HaniAbuelkhair4
I found the issue its the Wins server
But i could not find away to setup the wins server on my DHCP setting
if you have DNS server you can set that on on the  Custom nameservers on the DHCP, but i dont know where can i force my wins server on the DHCP
Only Client VPN you can see the  Custom nameserver for wins not the DHCP
I remember that the we have the DHCP option but dont know the ode for Wins any help please
HaniAbuelkhair4
Thanks @PhilipDAth
