Umbrella blocking employer.carefirst.com ?
from_afar
Anyone else seeing employer.carefirst.com being blocked? Strange because member.carefirst.com works OK, but employer just sits there until it times out. I don't see anything being blocked in the Reports, but I don't have anything else that could be blocking it.
I tried adding to the "allow list" destination list as well as the allow list in URL blocking in Meraki interface.
I'm just wondering if they are blocking the proxy addresses or something because I don't see what else is blocking it (I can get to the site fine on WiFi which is on a different network that doesn't run on Meraki or have Umbrella).
from_afar
Adding the URL to the Bypass Umbrella, Domain Allow lists, URL filtering allow list and AMP bypass did not work. However, adding it to Domain Management > External Domains & IP's in Umbrella finally allowed it to load. I don't understand why it didn't show in any of the reporting as being blocked nor proxied, passed all Policy Testing tests and especially why the Bypass Umbrella "Specify one or more domain names below (one per row) to be excluded from being routed to Cisco Umbrella." entry did not work.
5 Replies 5
RWelch
Reputation Lookup || Cisco Talos Intelligence  doesn't show it's a threat.  I would look to see if you happen to have certain countries allowed/prohibited (maybe)?
from_afar
Thanks. No countries being blocked. Finally got it working via Umbrella External Domain and IP list. 😤
from_afar
Brash
Adding the domain to "External Domains & IP's" essentially completely bypasses Umbrella for requests to this domain. Given adding it to the whitelist didn't resolve it, it's most likely it was being impacted by:
 - Intelligent Proxy
 - SSL decryption (if you're using SWG)
 - File Analysis
from_afar
Possibly. I added it to every bypass/whitelist I could find and only the final step actually worked. Maybe I missed one? I have Health and Fitness (it is an insurance website so should fall in there) selected as Exempt in Intelligent Proxy/SSL selective decryption exemptions. File analysis is not enabled.
I also thought that adding the domain to Meraki UI > Security & SD-Wan > Threat protection > Umbrella protection > "Specify one or more domain names below (one per row) to be excluded from being routed to Cisco Umbrella." would completely bypass Umbrella but that didn't seem to work...
