I need to understand the traffic flow for the setup of a vpn tunnel between a on-prem MX 250B and a z3 and/or z4.
I also need to now what ports are required and ips.
As far as I understand at this time.
the Z3's register with a VPN registry, somewhere.
When they want to start a tunnel, the registry reaches out to the MX250 with their public ip.
Then the MX250 sets the tunnel up directly?
thanks,
Davidt
I'd really recommend having a read of this:
https://documentation.meraki.com/MX/Site-to-site_VPN/Meraki_Auto_VPN_-_Configuration_and_Troubleshoo...
Key point: what you need to configure (assuming your MXs are claimed and have basic config) will appear under ? > Firewall info in the top right of the Dashboard.
Thanks, I did read that and everything is up and running fine. The issues are that security wants to lock communication to the bare minimum.
So I need to know what side initiates, what the traffic flow is etc.
Is that document saying that a tunnel is set up, MX---registry---Z3 ? or MX---Z3 after consulting the registry? because if that is the case we would need all public ips.
The vpn tunnel is setup between mx.
Ports used for IPsec tunneling:
Source UDP port range 32768-61000
Destination UDP port range 32768-61000
Between mx and the remote z3s?
MX must initiate it then, correct.
So we are looking at a rule...
MX internal ip (port range UDP 32768-61000), to any internet ip (UDP port range 32768-61000), for the tunnel?
Dont need any well known ike, ipsec ports etc, correct?
and then just a rule for MX to register with the meraki cloud.
Tunnel is build from the public ip.
You need to check help>firewall info on the dashboard
All devices register their IP address and [usually dynamic] port with the VPN registry.
When any device (MZ, Z3, etc) needs a VPN to another device, it looks up the VPN registry to get the IP address and port of the other device, and builds a VPN directly to it.
