Traceroute from a VLAN
amabt
Am I missing something here or there is no way from the Dashboard to do a traceroute from the MX as if you were on one of the internal VLAN. It seems you can only do a traceroute from an Internet interface?
We need to be able to see the exact path a device on a specific VLAN takes to specific destination without having to jump on to the host.
Unfortunately traceroute is only available for WAN interfaces.
You can have a virtual machine to run the tests when needed.
You just need to think outside the box sometimes.
why don't you want to traceroute from a workstation? The result will be the same.
amabt
Not in all case you will have access from a workstation and or need to quickly check for issue before contacting the user and jumping on their workstation.
Example we have a network where there are only custom Andriod devices with no way to do a traceroute from them.
amabt
Thanks for the confirmation. Just wanted to check in case Its there and I can't see it.
I guess I have to put it in the wish list!
