Client VPN For android
SardarAlam
Hi All,
I want to configure Client VPN for Smart phone just like we using in windows, How it possible can someone help and share the procedure how to enable or configure in phone.
Thanks in advance
This documentation is to configure on the MX now you just need to download the app on the play store.
Google
6 Replies 6
You can easily find this googling.
https://documentation.meraki.com/MX/Client_VPN/Client_VPN_OS_Configuration#Android
SardarAlam
Android devices running Android 12 and above do not support L2TP/IPsec VPNs. Devices with existing configurations will continue to work. Client VPN connection cannot be configured on new devices.
We do not have any old version phone, i need for Android 12 and above, Please suggest a solution.
In this case the best option is the Anyconnect.
https://documentation.meraki.com/MX/Client_VPN/AnyConnect_on_the_MX_Appliance
SardarAlam
Which option should i use for Andriod?
Google
SardarAlam
Thank You for swift response.
