Template unique subnet generate Error
Dear expert ,
I have created template to sync config to network from the dashboard. (Note that , my dashboard just created, currently no device (MX) has added). i just do pre-config.
My problem is that , when i go to address  & Vlan . i try to config unique ip , so i what input as below:
"/24 from 10.0.0.0/16 10 VLAN20 Auto-generated User_Vlan10" copied from the dashboard.
then it got error and says :
"Failed to autogenerate 1 unique subnet for VLAN '10' : subnet pool '/24 from 10.0.0.0/16' has 0 subnets available.
and then it turn me to its own configuration :
/10 from 10.0.0.0/8 10 VLAN20 Auto-generated User_Vlan10
could you help on this ?, currently i need to preconfig on template and add device later.
what has i done wrong ?
5 REPLIES 5
Re: Template unique subnet generate Error
This happens when you have two templates using the same supernet or overlapping supernets.
You can ask support to disable unique IP addressing checking - but then it is up to you to make sure it is correct.
hi @Philip , Thanks for you reply but currently i have only one template not two
I wonder if this has something to do with their being no devices in the organisation.  Was this template of type "combined"?
Dear Philip ,
you are right , i use combined network .
you can try to create an organization , without device and follow the step that i do , you will see the error.
i don't know why
Do you have any solution for that ?
